18-Opal
Can I refresh dashboards through events?
Hello
There are no events on the dashboard.
To refresh the data, you need to add the AutoRefresh widget to the gadget, which you can add to your dashboard.
What if I want to refresh the entire dashboard gadget from outside the dashboard?
If you have a good idea, please help me ..
regards,
SeonHo
Hi @CHASEONHO when you say this event needs to be fired from outside the gadget, is it depending on an independent action may be by the user? Could you add some more detail on the use case?
CHASEONHO18-OpalAuthor
18-Opal
Sorry, we didn't use dashboard
we decide use repeater widget
thanks
