18-Opal
October 25, 2017
Can I set the data field?
  • October 25, 2017
  • 1416 views
Hi i'm SeonHo
Can I set the data field at time series chart?
here are two data that temp, humi
and mashup has two check box that temperature and humidity
if checked temperature and unchecked humidity
then time series chart display only temperature data field
if checked both data
time series chart display both type that temperature and humidity
can possible? thanks
Hello, Seonho Cha.
I'm wondering if what you need to use is a Contained mashup to display the second selected data type.
The below article hints at what I'm talking about; instead of using a Menu widget you would be using the Checkbox.
Article Viewer | PTC
-- Craig A.
