Can large amount of data be stored in Infotable?
I need some inputs on implementation side.
I need to store string data in 5-6 columns of Infotable. If the size of data increases, would it impact the performance of TW application as data is stored in-memory for Infotables.
Also, when should we use or what should be the valid use case to use InfoTable and Datatable? Can we use these 2 interchangeably?
