Can not create container for Thingworx Analytics API Router.
Hello
I have allocate 6G RAM to the Docker daemon and share the driver C, but it occurs problem still
int the attachments is my install logs file
How to fix this?
Thanks and Regards,
CCi_9
CCi_9Answer
I had knowed what happen to it, I shuold close the firewall when I install it, and I should  close and restart the docker after setting up.
Thanks for you help.
Best Regards,
CCi_9
Hi
Could you indicate:
- what is the version of docker you are using ?
- what is the version of ThingWorx Analytics Trial edition you are using ... just give us the exact complete name of the installer exe file you execute.
- what OS is this ?
Thank you
Christophe
CCi_91-VisitorAuthor
I'm sorry to reply to you so late.
- the docker version is 17.09.0-ce-win32 (downloaded from the official website)
-the version of  ThingWorx Analytics Trial edition is AnalyticsTrialEdition-8.2.0-r3-windows-installer.
-OS is win10
Thanks a lot.
@cmorfin
this is the  version of ThingWorx Analytics Trial edition i am using.
Thank you
