Can't add row for infotable in runtime
  • February 27, 2017
  • 4 replies
  • 2932 views
I want to create new infotable from datashape, then add rows to it.
I get an error:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Invalid Reference to Object In Script
This is the code I use:
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "MyInfoTableDataShape"
var myInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for(var i = 0; i < Logs.length; i++){
var newEntry = new Object();
newEntry.DateTime = logDateTime;
newEntry.Reason  = log.Reason;
myInfoTable.AddRow(newEntry);
var result = myInfoTable;
When I add rows to an infotable property and add - var result = myInfotableProperty it works like a charm.
Hi Assaf Elgov​,
You're referring a different variables in your script, such as: Logs, logDateTime, log.Reason. Are you sure each is a valid variable / parameter?
What version of Thingworx do you use? What parameters of what base type you pass to this service?
J.
aelgov1-VisitorAuthor
It is just part of the code not the whole code.
I'm 100 percent sure it is valid, I logged them.
TWX version: 6.6.9
all strings besides 1 which is number
Assaf, you missing "." for adding DateTime from Logs, shouldn't it be
newEntry.DateTime = log.DateTime;
Because I use alot log.DateTime I inserted it into var called: logDateTime
