Can't find JDBC Connector
I want to connect Mongo DB to Thingworx. I know JDBC connector is required but could not figure out where I can find the connector extension files. It seems to be removed from Marketplace and I did not understand this post.
Thanks.
PaiChungAnswer
22-Sapphire I
I don't see any anymore no the market place.
There are ways to do it yourself
I dug up a former extension that was posted that helps create jdbc extensions
it will require you to have the proper jdbc jar file
Can't guarantee up to what version it will work.
also here is the official current directions from our support site
https://www.ptc.com/en/support/article/CS192961?&language=en&posno=1&q=jdbc%20extension&source=search
PaiChung22-Sapphire IAnswer
22-Sapphire I
Support
Hi @Toshihiko.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others on the community.  If you still have questions, please let us know.
--Sharon
