Oct 15, 2024 9:17 PM UTC
Can TwoDThumbnailURL.URL be downloaded and the file saved to a Thingworx File Repository using code
Hi @BjoernRueegg,
Reference from topic.
Can the TwoDThumbnailURL.URL be downloaded and the file saved to a Thingworx File Repository using code either in a Thingworx Service or Java?
Thank you,
Maria
TonyZhangAnswer
Support
Mar 5, 2025 7:33 AM UTC
Hi @mariaSutton,
Check out this article for how to save the image to File Repository given an image url.
Nov 7, 2024 2:38 PM UTC
I am not sure what data teh URL returns, if it returns image/* data, it can be saved to file repo.
TonyZhangCommunity ManagerAnswer
Support
Hi @mariaSutton,
Support
Mar 10, 2025 2:57 AM UTC
Hi @mariaSutton,
It appears that a response answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate the appropriate reply as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
