Can we bind dropdown to a infotable without datashape?
Hi Team,
Can we bind dropdown to a infotable without datashape? If so how?
Is datashape required for all the widgets to bind on?
22-Sapphire I
The only widget that I know that can take an infotable without a datashape is the Grid.
What is your challenge that you don't know the datashape
vijay51-VisitorAuthor
So we can create n no. of datashapes if there are  n no. of services that returns infotables
I hope there is nothing memory impact of datashapes as they are comparable to types in java
22-Sapphire I
Correct also if you execute the service and it returns an infotable (without needing a DataShape initially to construct it) Thingworx gives you the option to create a DataShape based on the result.
Creating a large number of DataShapes shouldn't be an issue.
With large I'm thinking 10,000 or less.
20-Turquoise
What dropdown are you trying to use? Like a List widget dropdown?
Where is your infotable coming from? If it's a property, it has to have a datashape.
20-Turquoise
Yes list widget
20-Turquoise
Where is your data coming from?
