Can we collapse/hide containers in Mashup Builder?
Using ThingWorx 8.5.7, is it possible to collapse or hide a container while working in the Mashup Builder?  For example, I have a fixed size container across the top of my mashup that is normally collapsed when users view the mashup.  A button click expands that container to display help and other information.  It's big (tall) enough that it takes up a lot of space on the screen when I work in Mashup Builder.  I would like to collapse or hide it while working on the mashup.  Is it possible?  For now, I change the fixed size to a small value to get most of it out of the way while I work on the mashup, then I usually forget to set it back to the normal size later.
CharlesJiAnswer
Support
Hi @DanWolf, I don't think it is possible yet as far as I know.
If you want to edit the main part without getting influenced by the container above, you can put the main part into a contained mashup, then you can go to that single mashup and finish your design. (Though, you may need to pass the values through session parameters)
You can also bring this idea up at the following board to request for such functionality:
https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas
CharlesJiCommunity ManagerAnswer
Support
DanWolf14-AlexandriteAuthor
Thanks for the feedback.  That header part is already a contained mashup, but I hadn't thought of making the main part another contained mashup.  That would add one more mashup layer, but I think that would still be doable.  I'll keep that in mind for the future.
