Can we get datatable values from thingworx to java with Edge SDK without service
i have java code in which i have connected to thingworx through appkey and i want to access data table values without service is it possible to retrive values without services?
ankiguptaAnswer
Hi Kedar Borkar​, It is not possible to read Data from DataTable without a Service. There are inbuilt Services in ThingWorx Platform to read and write entries from/to DataTable.
Hi Kedar, you could test this by making a REST call from your Java code - though that will also use the service from the DataTable to get the values. Have you already tried that? Else any reason why you don't want to create a service for this? Any specific use case?
kborkar1-VisitorAuthor
I will try with that no specific use case just want to know whether it is possible or not.
ankigupta5-Regular MemberAnswer
Okay i will try with invoking Services for reading and writing entries.
