Can we make grid column editable to non-editable from service (TWX9.1)
Hi
I am facing one issue where i need to keep column in grid as non-editable when particular column name is not configured in another table. column will be editable only when that column name is configured(in another table).
How we can achieve it.
Hi @VaibhavShinde,
The Grid Advanced's "IsEditable" parameter can be bound to a boolean property to change dynamically whether the Grid is Editable or not :
I don't think however that this can be done for each column individually.
Hi @c_lowy ,
Thanks for reply but i was looking for something else..i want to keep column in grid editable based on some value in service.
@VaibhavShinde, could you give an example ?
