Cannot access Thingworx Server web pages
I installed AnalyticsBuilder trial edition on Windows 10. Everything works fine at the beginning. I can access http://10.0.75.1:8080/Thingworx and finish tasks following the tutorial. After several hours, I found I cannot access the web pages. IE shows:
Can’t reach this page
Then I tried a different IP 10.0.75.2 and it works. After a weekend, I cannot access Thingworx web page by any IP. I have tried to restart the services. It doesn't work.
I have cleaned everything and reinstalled ATE again. The installation log shows everything is fine, but the problem is the same. The web site only works for few hours.
cmorfinAnswer
Hi
Okay, so the twxfoundation, edgems and nginx containers are in Exited state, this is why you cannot access ThingWorx.
You will need to start them manually: docker start twxfoundation for example.
Make sure you have allocated at least 6 Gb of RAM to the docker process, and ensure your local machine has at least 16Gb of RAM.
Kind regards
Christophe
Hi
Could you post the output of the below 2 commands
docker ps -a
ipconfig /all
Christophe
cmorfin19-TanzaniteAnswer
Hi
Kind regards
Christophe
The problem is solved. Perfect.
