cannot delete and import GoogleWidgets_ExtensionPackage
dear sir,
I follow ThingWorx Foundation QuickStart steps on my 30 day foundation server,I bind  'house_lat_long' to the 'SelectedLocation' on the googlemap widget ,view mashup then I got 'MissingKeyMapError' in my chrome client.
so I want to delete the extension 'GoogleWidgets_ExtensionPackage' and import to update its api key,like this:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?key=[my api key]&amp;sensor=false" description="" isDevelopment="false" isRuntime="true" />
but when I try to delete the extension , I got this ,should I delete the dependencies first??
Extension Package deletion failed: Unable to Invoke Service DeleteExtensionPackage on PlatformSubsystem : Cannot delete ExtensionPackage [GoogleWidgets_ExtensionPackage] because the following ExtensionPackages depend on it: [TWX_Converge_Core_ExtensionPackage]
Hi Karen, can you check if there are any objects created using that extension?
edit:
just wanted to confirm if you are importing this extension on the same server as mentioned in your other community thread Can't launch my 30 days foundation server
Since that server is not yet up, once it up you can give it an another try.
Sushant, the library dependency in this error is from Utilities. I believe this customer will need to remove ALL (or at least most) of their extensions, update this one, and then reimport them. Is there no way to update what they need without having to reimport the mail extension?
Tori, you're right i totally missed that, i guess then Karen Chien​ could give your suggestion a try. Though i still got to check about that instance start up.
