Cannot import customized localization table
The default localization table , like zh-cn cannot assign project.  I have to export it separately after exporting the source code by project.
So I create a customized localization table called zh ,  but it's tokens  cannot be imported  although the tokens really get exported in the xml file .   Is this a know problem ?
ThingWorx version : 8.5.5
Sean
anarwalAnswer
anarwal5-Regular MemberAnswer
Hi @seanccc , It will helphttps://www.ptc.com/en/support/article/CS271320
Support
Hi @seanccc.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
