6-Contributor
Jul 20, 2018 2:24 AM UTC
Cannot Import 'Gantt Chart Widget' extension into Thingworx 7.4.11
I'm trying to import 'Gantt Chart Widget' extension and I get the following error:
[context: Extension Exception]
[message: Error parsing /ThingworxStorage/extensions/temp/GanttChartExtension_v1_126a19f6-1311-4d2b->b121-32621e99865c/GanttChartExtension_v1/Entities/DataShapes/GanttChartData.xml: (9, 15): cvc-complex-type.3.2.2: Attribute 'universal' is not allowed to appear in element 'Entities'.]
Any help is appreciated.
Thanks in advance,
Nakaya
vxavierAnswer
Jul 20, 2018 5:57 PM UTC
This Gantt Chart is not workink properly.
You will have to enter in the Gantt Chart Files and delete the Universal property in each .xml file inside "Entities".
After that this entities just will work as a guide, neither will work properly. You will have to create a new data shape, data table and new mashup to test the Gantt Chart. This worked for me, hope it works for you too.
This was exactly what I have done, attached is the zip file that worked for me.
Cheers,
Vinícius.
vxavier5-Regular MemberAnswer
Cheers,
Vinícius.
knakaya6-ContributorAuthor
6-Contributor
Jul 23, 2018 5:55 AM UTC
The file you attached worked very well!
Thank you for your help.
Nakaya
