Cannot save datashape
Hola,
I've been trying to create a datashape but i keep getting this error. Does anyone know what this is or ideas?
save failed, status: error message: Import Failed: Unable to create data shape: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]
Hi @wsuen are you getting similar error while creating any other entity? How are you creating this DS, via a service or manually via the composer?
wsuen1-VisitorAuthor
I'm creating it manual in the composer. I am only getting it on the datashapes. I'm using version 8.0.6-b56
I have seen this error occurring when there's some connectivity issues between the ThingWorx and the Persistence provider, which persistence provider are you working with? Can you put the application, script log in trace mode and then reproduce - to see if there's any additional info generated in the log.
