Change Line Color Based on State Formatting
I am using the LabelChart widget, and need to change the color of the line based on state formatting. Is this possible? Should I use another type of chart widget?
I've been able to change the color of the 'on hover' action based on state formatting (by using the 'SeriesDataStyle1' property of the widget), but not the line itself.
Support
Hi @ague.
It is possible to edit the color of the line using either CSS or style definitions/state formatting based on the needs of your use case.  But in the case of a line, what criteria determines the line color?
If this does not guide you to a solution, please provide more details around your requirements.
--Sharon
Support
Hi @ague.
If my previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Support
Hi @ague.
If you have found a solution to your issue, your indulgence in posting it here for the benefit of other community members would be greatly appreciated.
--Sharon
