11-Garnet
Change text color of elements of tree widget based on different conditions defined on service.
I want to change text colors of tree widget elements based on different conditions.
The tree is created based on infotable which is output of a service.
Need to add logic on service to change the text colors, Are there any way to achieve this ?
Is it possible to add state definition on service ?
Use "TreeFormatter" widget property with statedefinitions to change the font/bg color based on the infotable field value.
For more:
