changing apache tomcat from 9 to 8.5 after thingworx installation
I have installed thingworx 8.5 with apache tomcat 9. but apche 9 is taking lot of cpu utilization. so thinking to change it to apache 8.5 what is the procedure for this?
18-Opal
Just copy "webapps/Thingworx" directory from old Tomcat home to the new one, making sure that both are installed on the same disk drive and configured similarly (see conf/server.xml). Stop 9.0 and start 8.5, it should just work.
Having said that -- don't do it, you probably won't gain any performance (if not lose).
/ Constantine
18-Opal
/ Constantine
Ujwal171-VisitorAuthor
What is the system requirements for 8.5 ?
I have installed thingworx 8.5 + apache tomcat 9 on 8 gb RAM ,will it affect the performance??
18-Opal
Here, check out the first link: https://www.google.com/search?q=thingworx+8.5+system+requirements
8 GB should be enough for prototyping and developing small-to-medium size applications.
/ Constantine
Support
Hi @Ujwal17.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
