Chart to display full label in x axis
Hi developer's,
                      I have small doubt regarding. How to display the Full label on the x axis,
I just don't want to display like this.
I want to display where I contains full name:
Hi @MK_9986318 ,
There is no property to adjust width of label area in label chart widget.
Try to implement these steps and let me know if that works for you:
  • Reset Label Chart widget property XAxisFormat value and add more 0s before decimal point
  • This is the way to manually adjust the width of the label area using widget properties
  • Use best combination for both XAxisFormat and XaxisLabelRotation together for proper alignment of xaxis label strings and avoid any cut off of label length on X axis
  • Example:
Regards
Bhawna
