Chart Widget Axis Formatting
On the chart widgets there is a property named, YAxisFormat, that is given a default value of "0000.0". My question is, what is the format string that equates to whole numbers such as, 1, 2, 3, ... etc.?
cmorfinAnswer
Hi @berkob
The format indicates the number of digit before and after the decimal marker.
So if you do not want decimal and only integer, you can use 000 if you know that you won't have number longer than 3 digits.
Hope this helps
Christophe
cmorfin19-TanzaniteAnswer
Hi @berkob
Hope this helps
Christophe
Support
Hi @berkob.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
