check if user has visibility on a thing
Hi all,
 I have a set of things (collected in a infotable) and I would like to know if the current user logged has visibility for each thing in order to show just his thing.
I would like to avoid to use GetImplementingThing function because if I will have a large number of Thing, the service will respond slowly.
Please see code below:
for (var x = 0; x < listLength; x++) {
 var rowPos = list.rows[x];
 var posInstance = Things[rowPos.PosThingName];
 try {
 if(posInstance.name) { result.AddRow(rowPos); }
 } catch(err) {
  This will work because the "posInstance.name" will return error
User does not have visibility permission for....THING_NAME
but this cause a large number of log error in monitoring and I would like to avoid that.
Is there a way to know if current user has visibility permission on a Thing?
You can use spotlightsearch instead (I don't know the performance...)
Istead of:
try {
 } catch(err) {
Use:
var any = Resources["SearchFunctions"].SpotlightSearch({
 maxItems: 1,
 searchExpression: rowPos.PosThingName,
 types: { items: ["Thing"] }
if (any.rows.length==1) { result.AddRow(rowPos); }
Istead of:
try {
 } catch(err) {
Use:
 maxItems: 1,
22-Sapphire I
I don't see why GetImplementingThings would be any slower, one way or another you are determining all potential Things and then pulling the ones that are visible.
Carles answer is correct.  I've validated and implemented in my current project.  The search services automatically determine user visibility and only return entities to which a user has access.
