Check permission for a specific user
Is there a way to check, from a service,  if a specific user (note: not the current user) has access to a specific entity ?
It would be enouth to check "visibility" access.
That service would be run by an admin-level user.
It should works like the " Permissions | Access Reports" utility on the composer
Hi @iguerra
Currently there is no OOTB service to quickly determine if a ThingWorx user has visibility to a ThingWorx entity
but please check this article there is a example code present in it which will return a Boolean of TRUE or FALSE if the specified user has specific visibility to the entity
Toolika Dixit
iguerra16-PearlAuthor
Hello @tdixit
this is what I'm doing ... checking Visibility permissions set directly on the entity, unfortunately this method does not consider the "collection" permissions.
The article is referred to thingworx 7.0 ... strange on version 8.5 or 9+ this is still not possible.
I found now that there is a service on CollectionFunctions -> CheckPermissionForUser
but it returns a boolean, and is not clear the function of parameters
// result: BOOLEAN
var result = Resources["CollectionFunctions"].CheckPermissionForUser({
	name: undefined /* STRING */,
	type: undefined /* STRING */,
	user: undefined /* USERNAME */
May be "name" is entity name , and "type" is the specific permission to check (visibility ... runtume execution...) ?
The service never gives error codes...
Hi @iguerra
"Check Permission for User" service is used to check if any entity has a specific runtime permission for a specific user
Parameters:
  1. name / Name of the resource(i.e property, service, event) to check : string
  2. type / Permission Type : String
  3. user / User name : USERNAME
Output : Boolean
Toolika Dixit
Support
Hi @iguerra.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
I can't use
always returns false, and never gives errors (also with bad parameters)
Can someone give a working example ?
I have Thingworx 8.5 SP9
@iguerra
yes you are right. Service is executing without result and error. I just tried the same service directly from the resources in 9.1 version but hard luck. May be i can check this internally and get back to you.
Mohit
Support
Hi @iguerra.
If any of the previous posts were helpful, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
