Chip Based Data Filter Widget
Can someone show me how to build the Service we are supposed to put the query into for this filter widget to work. I have a service that brings the data back from the SQL server. But I do not understand the QueryFilter property to the query input parameter of the QueryDataTableEntries service in this reading.
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/Grid_SortingAndFilteringTheGridData.html
Please send or help if you can thanks.
22-Sapphire I
I think nowadays in the mashup builder if you click on it, doesn't it provide some ui to build the query? (sorry its been a while)
Else it needs to be a json: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/Things/ThingServices/QueryParameterforQueryServices.html
This would be for the new Chip Based Data Filter widget I have watched the videos and read the documents but it does not show how to bind that query to the service to make it work. I just wanted to see a service where it has the input of query and how it works. I can get the data and bring it to the grid advanced and everything I just wanted to let the users be able to filter the data with this chip-based data filter widget.
I have a service where I create an infotable from a \query to SQL database.
var dt ;
//pull data off of the database table Get Cooker Historical Data based on passed in parameters
dt = Things["LOL.ThingWorxLOL_Prod_DB_Connection.DB"].Get_Cooker_Data({
Start_Date: Start_Date /* DATETIME */,
End_date: End_Date /* DATETIME */
me.Infotable = dt;
This brings me back the data I need from Start_Date to End_Date.
Can someone help me add a query filter that I can receive from the Chip Based Data Filter Widget please as I cannot figure out this query filter option?
I would be greatly appreciative.
