Clean Way to Create users for application
I searched for Clean way to create a user permission for a project but i didn't found.
Each time i try to create user for application , i always face a lot of bugs like: entity not found , you have no permission to execute event ...
I alwayd verify all permissions and i get the same blocking points so my question is;
Is there one propre way to create a user for a project, this user can do what he want only in this project (Full rights in runtime and design time + Visibility )
Steps:
1- I created Organisation
2- Created two groups (Admins groups and simple users groups), each group contain a user .
3- I add right access to the two groups (Visibility, design Time , Run time) to all entities (mashup, Things, Thing template, Thing shape ...).
4- Authantificate with the admin user created for the application
5 - Errors : Not Authorized to edit entity subcription script
I can add this entity to Permissions -> Collections .. and give the edit right  to all entity but now the user ca see other things of other projects!So,  i don't think this is the proper way to do it (may be)  !
WHAT IS THE CLEAN WAY TO CREATE A USER WITH FULL RIGHT IN A PROPJECT IN THINGWORX ?
Thank you for your help !
PaiChungAnswer
22-Sapphire I
PaiChung22-Sapphire IAnswer
22-Sapphire I
Support
Hi @AliBenBelgacem.
If the response provided by @PaiChung allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
