clear value streams
Hi everyone!
I have created a value stream to do test but I wanna clear the values storaged.
How I to clear the data storaged on the my value stream?
raluca_edu
You can use PurgeAllPropertyHistory service at the Value Stream level.
This service will clear data in a time range specified by you.
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
Thank you @raluca_edu it helped me a lot
Regards
Leonardo
