By cloned you mean you have the exact same data in staging as Prod? Your staging environment must be on different server and must have a separate database, right?
sabharees15-MoonstoneAuthor
Yes, server and DB is different.
If nothing is shared between the servers then I don't think there will be any issue since they are independent instances.
Sachin Sharma
