code completion
Hi guys.  How do I turn code completion on and off in my composer?  I've been writing services and widgets for a couple years now and all of a sudden, code completion was turned on a couple weeks ago but then it went away.  How do I get it back?
As far as I know, TW doesn't have code completion on the Standard. Once said this, if you go an install the MonacoEditorTWX extension which brings Visual Sutdio Code editor into TW Composer you get also code completion, here you have the download: https://github.com/ptc-iot-sharing/MonacoEditorTWX
Carles.
Carles.
sjoyce10-MarbleAuthor
I've installed the Monaco editor on my test machine and the thing works for me, but it doesn't work for anyone else, and I'm not sure why.  It's also missing some friendly ribbon buttons, so I had to use keyboard commands, but that seems fine.  Code completion part works fantastically.
