Collection widget not working / invisible
- 6 replies
- 4376 views
- Translate All
Dear community,
I am experiencing an issue with the Collection widget on our development system. I have a Mashup using Collection widget and it worked fine for several months. From one day to the next the Collection widget (or rather its content) was not visible anymore, the space is simply empty. I have not changed any settings or anything else on the server or environment but cannot 100% guarantee that none of my coworkers changed anything.
- The Collection widget does not work on any Mashup. I created a new one from scratch, same behavior.
- This only occurs on the dev system, so far no test or prod system is affected. I exported the working version of the Mashup from prod back to dev - still empty.
- The bound data is for sure NOT the issue, the good old repeater is working like a charme using the same data source.
- I observed a similar behavior in the beginning of our project when you first have to check "Enable Beta Mashup Features" on PlatformSubsystem -> Configuration. But this cannot be the problem because other Beta features (like the Tab) are still working well. Nevertheless I even tried to uncheck, save, check, save and test again with no result.
- At the moment I can only test on Chrome (78) and no other browser due to another issue on our dev system.
- We are running ThingWorx 8.4.4-b2319 on all systems. I would like to avoid an upgrade if possible, especially because it once worked fine and still is on all other systems.
- I have not seen any error message, neither in ApplicationLog nor in Chrome Console.
- I haven't found any related topic in the community. The closest was this thread but changing the item load behavior did not change anything. I also tried randomly changing all other properties - no change
- I attached the latest version of my Mashup but testing is difficult without the supporting Services.
Any help is appreciated. Thanks.
Benny
