Collection Widget Row Spacing (table view)
I'm trying to put some vertical space between rows in a collection widget when it is in Table view.  There is a RowSpacing property but it only seems to apply to the Flow view. I've been playing around with the CSS but I can't seem to get anything to work.  Any thoughts?
I have a workaround that almost gets me there (making the row a bit taller and put in a container that is the same color as the background of the main mashup), but then the border radius doesn't look right.
GabrielBAnswer
Hi @nmilleson ,
There is a very simple way of overcoming this. Set your Collection on Flow layout. Set the FlowLayoutGravity to Expand, FlowLayoutAlignment to Top and FlowLayoutContentGravity to Top. And set the MashupWidth to 9999 or something crazy like that. It will basically occupy the whole with of the collection container no matter what. Then you can set the spacing between the rows.
Good luck,
Gabriel
Support
Hi @nmilleson.
Here is a guide that may help in using CSS.  For your specific scenario, we will have to test it.
--Sharon
nmilleson17-PeridotAuthor
@slangley ,
Thanks for the reply.  I am pretty familiar with using CSS on the widgets, I just can't find where I'd be able to change that vertical spacing on a table view collection widget.  There are a few places where I can change margins and padding in the browser console, but they don't seem to affect how the rows are spaced.
Thanks!
Nick
Support
Hi @nmilleson.
We've been looking at this, but need clarification of your intent.  You mentioned vertical spacing on a table, which would mean between the columns, but later mention row spacing.  Just need clarification.
There are properties for MinimumSpacing between the cells in the Row.  There is also RowSpacing that affects vertical spacing between the rows.
Have you tried the above and it's not working for you?  We did not find an issue under 9.1.  Which version of ThingWorx are you running?
--Sharon
GabrielB12-AmethystAnswer
Hi @nmilleson ,
Good luck,
Gabriel
@GabrielB ,
Thanks for the solution!  We also have a requirement that the corners of each collection tile need to be rounded.  It appears that your workaround still shows the rounded corners on the right-hand side of the screen!
@nmilleson glad it helped!
