Collection widget scrollbar
is there a way to switch off the scrollbar on a collection widget (when it is not required). I have a number of instances where I use the collection widget and there is only one row, so no requirement to scroll. However, whenever you hover over the widget the scrollbar appears whether or not scrolling is required. In the Thingworx version we have there is the option to change the scrollbar to only appear when hovering, but not a way to hide it that I can see.
K
khayes1Answer
thanks for the reply. your email got me thinking so it tried it on a later server and the issue appears to be fixed.
Originally I was using 8.2.4 b235 but upgraded to 8.2.8 b856 and the problem went away.
K
Support
Hi @khayes1.
Please let me know which version of ThingWorx you are using so I can test it.
--Sharon
khayes11-VisitorAuthorAnswer
K
