6-Contributor
Common Url for the user for login into different Applications
i am using Thingworx applications, which was enabled with SSO, i have totally 3 plants with different url's when the plant person login into common Url it should be redirect to particular URL of the plant person, if the user was assigned with  all plants it should shows the 3 plant link details after clicking the particular plant it should redirects to particular plant to access the application of the user. how can i done?
Hi @NN_13870674
Could you please review the article below and let us know if it is helpful for your use case?
https://www.ptc.com/en/support/article/CS393256
Support
Hi @NN_13870674
Did you find the previous response to this post helpful?  If so, please mark it as the Accepted Solution for the benefit of others in the community.
If you still have questions, please let us know.
--Sharon
