3-Newcomer
Aug 26, 2025 11:34 AM UTC
Compatibility of Thingworx Foundation 9.7.2 with Windows Server 2025
Hello all,
I would like to install Thingworx Foundation 9.7.2 on a new server and would like to know if this version is compatible with Windows Server 2025 (since Windows Server 2022 will reach the end of standard support in 2026).
Thank you in advance for your support.
Rocko
RockoAnswer
Aug 26, 2025 12:45 PM UTC
Release advisor only lists Windows Server 2022. https://release-advisor.ptc.com/releaseMatrix?releaseId=2434
So while it's highly possible it will run under Windows Server 2025, it will not be a supported configuration.
I recommend going to TWX 10 which will support WS 2025 later on (not yet).
Rocko
Rocko19-TanzaniteAnswer
3-Newcomer
Aug 27, 2025 12:37 PM UTC
Thanks you !
Support
Sep 1, 2025 6:59 PM UTC
Hi @CN_12920402,
It appears that this post may answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
