Configuration of SQL Server on thingworx platform.
Hello, I am facing the same problem while configuring the MS SQL server with ThingWorx-Trial-Edition-8-2
https://community.ptc.com/t5/ThingWorx-Developers/Re-Need-files-related-to-configuration-of-SQL-Server-on/td-p/524016
I am trying to configure MS SQL server to thingworx. As per the installation guide it says
" Obtain the database setup script (thingworxMssqlDBSetup.bat) from the ThingWorx software download."
But in the download folder I don't see this file. Can you guide me in getting the required file.
Where can we find the file?
Best regards
As far as I know, only H2 Persistence Provider version is available as trial.
H2 in the below file name shows which Persistence Provider ThingWorx is using.
"MED-61182-CD-082_SP1_Thingworx-Platform-H2-8-2-1.zip"
The file name of Ms SQL  version should be something like "Thingworx-Platform-Mssql-8.2.1".
