Jun 16, 2020 11:26 AM UTC
Configuration Table containing infotable property, saying must have Data Shape defined
I have created an infotable property in a configuration table and I have defined this structure in the data shape assigned also but when I try to view the infotable inside the configuration table it says 'must require a data shape defined'. But I have defined a data shape for both the configuration table as well as the infotable property inside the table. Wanted to know why this is occurring for a nested info table even if there is a data shape defined it says must have a data shape.
Hoping for a reply soon.
Thanks in Advance
With Regards,
Srijith
slangleyAnswer
Support
Jul 14, 2020 3:52 PM UTC
Hi @SrijithKrish.
I apologize for the delay on this.  I had previously recreated the issue you reported under ThingWorx 8.5.6, but needed to also confirm under the latest release, 9.0.  Due to the need to work other cases already in progress under 8.5.x, I was delayed in upgrading.
However, I have now upgraded to 9.0, and no longer see this issue.  @VladimirRosu_116627, if you've upgraded as well, perhaps you can also validate.
--Sharon
Jun 16, 2020 11:33 AM UTC
Quick question: what ThingWorx and browser version are you using?
Jun 16, 2020 11:35 AM UTC
@VladimirRosu_116627  ThingWorx version is 8.5.4
Jun 16, 2020 11:38 AM UTC
Browser Version did u mean my chrome version?
If Yes -  Chrome Version 83.0.4103.97
