Configuring existing property to isPersistent
Hi
I wanted to know can I configure an existing property which is not persistent currently into persistent using a service? Like it would make a manual process simpler if there was say more than 100 properties in a shape or template. Is there a way to set isPersistent to true through a function?
mnarangAnswer
Currently, there is no OOTB service/snippet to update the property definitions/aspect .The only possible way is to either delete and recreate with required configuration/aspect or update it manually.
Thanks ,
Mukul Narang
mnarang5-Regular MemberAnswer
Thanks ,
Mukul Narang
Hi @mnarang
Thank You!
Just a suggestion , it would be nice if there was a facility like that in future.
This type of feature is already in discussion ,will update you once it is out with new release of ThingWorx.
Thanks ,
Mukul Narang
