Connect OPC UA server
I want connect OPC UA server with thingworx using OPC UA Client Extension which is downloaded from marketplace.
I can't able to connect with thingworx.
I have pasted "config.json" and "Thingworx_OPC_UA_Client.jar" at "C:\OPC".
I have modified "config.json" file and started "Thingworx_OPC_UA_Client.jar". At, thingworx property "IsConnected" not updated.
Where i have made mistake?
Thanks.
Hi @Sathishkumar_C is there a specific reason why you are working with the Extension and not via the Kepware? Please note that its highly recommended that Kepware is used for connecting industrial devices. You can check the application connectivity for Kepware here
