Connecting external API into Thingworx
I am trying to connect external API into Thingworx.  But i am unable to receive responses.  I attached my code here.  and i upload my result also.  Please help me to do that.
Code:
var params = {
proxyScheme: undefined /* STRING */,
headers: { 'grant_type':'*****','client_id':'******','client_secret':'******','resource':'*******'},
ignoreSSLErrors: true,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: "https://******", /* STRING */
timeout: 6000,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
Did you test the API call before with a more "raw" tool like Postman or Curl?
DMu31-VisitorAuthor
It's working perfectly in postman... But I am unable to get response from thingworx...  Please help me to do that...
DMu31-VisitorAuthor
How to pass our body into params region because when i am executing the services it is taking url alone or it is printing header section alone.  I need to get access token as a output.  I passed my url and i declared input values like grant_type,client_id inside the content.  if i run these things i am unable to access token.  My url is working fine in postman.  please help me to resolve this issues.
Thank you
can you get the output for the above issue.I am also working on similar to your code.I am also getting the same issue
karthik
