Connecting the MQTT Broker of the Fischer Mini Factory to Thingworx
Dear All,
I just got Thingworx and I'm new to the program.
I want to connect an extern MQTT broker via an IP-Adress with Thingworx. I already imported the MQTT Extension Kit into Thingworx.
Unfortunately I can't establish a connection to the Broker.
It would be very nice if someone could help me to connect the MQTT Broker to Thingworx so that I am able to get access to the IoT data and can use them in Vuforia Studio
Yours Faithfully,
Marius
Here is a list of helpful materials on this topic:
Hey Vladimir,
I tried all the links mentioned above. Unfortunately there is still no connection. I entered the IP of the broker : Connection->Server Name: XXX
Also the user and the password, which I use in the MQTT Explorer program to look at my IoT-Data, are saved in the project.
As mentioned above, still no connection.
Try "Open a Support Case", here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
