Connecting to Power BI
Hi @amiriqbal0711 ,
I have the same use case requirement , could you please tell me how you are accessing the Power Bi report with login credentials in the first place ?
Thanks in advance.
PaiChungAnswer
22-Sapphire I
Generally I would recommend just a 'link' to Power BI reports and have the user login (or use SSO)
To show within ThingWorx, there is the webFrame (iFrame) widget but with security settings etc, it could be quite a hassle to make it work seamlessly. It is possible but would take a lot of work I believe.
Power BI does have a Rest API that might help in various ways.
PaiChung22-Sapphire IAnswer
22-Sapphire I
@CG_9923935  Did you get a chance to implement last solution suggested in this thread. If that was helpful please make that accept as solution for the benefit of other community members.
Mohit
