Consume REST API that needs token
Hi All,
I need to use a web service that needs authorization and consumes a token for it.
I know that I need to use some of the snippets function (ContentLoaderFunctions),
but I need someone to provide me some kind of example 'cause none of them has a field that uses my token.
Anselmo.
Looks like we cant use a webservice that consumes a token...
And that's the answer.
22-Sapphire I
You will most likely need to declare that token through the header.
Something like "token:laksjdflksdajfladsjfjdsk"
Something like this?
var token = {token:"abcdef"};
var params = {
headers: token /* JSON */,
ignoreSSLErrors: true /* BOOLEAN */,
url: "http://mymachine:8080/myapi" /* STRING */,
timeout: 30 /* NUMBER */,
Well, it didnt work out.
See the error mesage below:
Error executing service MyService. Message :: Connect to 192.168.229.139:8080 [/192.168.229.139] failed: connect timed out - See Script Error Log for more details.
Nobody?
Hello?
22-Sapphire I
When you tried that call what was the response? Check application log.
Can you list the actual documentation of the API call?
The only response I received was this error mesage:
Documentation (my command is described in the page 26):
http://help.geautomation.com/Historian55/Subsystems/iHistGS/content/restapi.pdf
Saitoisonfire1-VisitorAuthorAnswer
