consuming external API
I'm trying to use an external API that requires a curl request. Is this possible using the content loader functions?
    Hi David,
    I think the functions in 05.01.03.03 ContentLoaderFunctions, specifically GetText will be perfect for this (but also check the other functions there).
    Available of course in the snippets 🙂
    BR,
    Vladimir
    davidcor1-VisitorAuthor
    can you provide me with an example? I'm trying to use an API that requires the request
    curl https://api.domain.com/v2/shipments \
    -u {YOUR API KEY}:
    I've used GetXML for other APIs but can't see how I would be able to consume this one.
    I've tried this:
    var url = https://api.domain.com/v2/shipments
    var params = {
        url: url /* STRING /,<br>    username: apiKey / STRING */,
    var result = Resources["ContentLoaderFunctions"].PostText(params);
    but get "unauthorized 401" as a response.
    are you having trouble with the spaces and the slash? Did you try using things like %20 or escape characters?
    Pai - I don't see what you mean.  there are no spaces in the url.  I opened a ticket with support and they said that the code below worked, but I still receive an unauthenticated error
    result = Resources["ContentLoaderFunctions"].PostJSON({
    url: "https://api.easypost.com/v2/shipments",
    password: "",
    username: "d7WlVQmMEFlzQ5a9GvbfXA",
    timeout: 30
    David,
    I assume you replaced the example API key I supplied as the value for username with the API key associated with your account?
