3-Newcomer
Nov 14, 2024 4:43 PM UTC
container scrolling behaviour
I have a main responsive mashup, It has two Sub Containers...
1st Sub Container has some static positioned labels that's why it's set to static.
2nd Sub Container has Collection Widget under responsive type container.
Now I see all two sub-container are having Scroll bars.
Is there a way, My Main Container has a vertical Scroll bar and sub-containers can expand as much as they can, without having any scroll bars?
Thingworx version: 9.4.6
Abhishek Kumar
TonyZhangAnswer
Support
Nov 19, 2024 2:39 AM UTC
Hi @AK_11420126,
What I would do is put Collection and labels into 1 container instead of 2 sub-containers, so that you will have 1 global scroll bar to control multiple widgets without any sub-scroll-bars for each child widget.
You can use properties to set widget width for example or use custom css to style the child elements of the "main container" if necessary
See below article which is similar use case.
https://www.ptc.com/en/support/article/CS422476
TonyZhangCommunity ManagerAnswer
Support
Hi @AK_11420126,
Support
Nov 21, 2024 6:54 AM UTC
Hi @AK_11420126 ,
Does my previous response answer your question? For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that my response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
