ContentLoaderFunctions GetText is not working in Thingworx 9.1
Hello.
I am using Thingworx 9.1 version with Postgre SQL.
GetText function is not working. Got error as "Invalid Content Type: application/json". The same code it was worked with Thingworx 8.5.1 version.
var propertiesAttr = Resources["ContentLoaderFunctions"].GetText(params);
Could you please suggest?
Thank you in Advance.
Latha
@vi1
GetText is working for me on 9.1, refer below screenshot,
Would you be able to the code you are using?
Sachin
vi116-PearlAuthor
Thank you for response.
Here I am using url path is outside of thingworx server. When I give the url path is inside thingworx, its working correctly and also if I use GetJSON with outside server url path, working correctly. Observation with GetText service with outside server url path. Refer the below snippet which I am using for GetText.
@vi1
Are you not getting any output or are you getting an error? If it's the latter, please share the error message.
Sachin
