Convert image to base64
  • June 26, 2018
  • 3 replies
  • 3888 views
How can I convert a image (media entry) to an base64 code?
Best answer by drichter
I solved it. I create a function with return type BLOB and this line:
var result = MediaEntities[image].GetImage();
22-Sapphire I
June 26, 2018
You can look into using the snippet:
var encodedValue = base64EncodeBytes(undefined /* not ready for baseType of "JSON" yet*/);
drichter1-VisitorAuthor
I know this function but i believe its not work with MediaEntities.
EDIT: Maybe I need a step that convert the image to an byte array
drichter1-VisitorAuthorAnswer
