18-Opal
September 28, 2017
Could you give me a documentation link on the types of protocols supported by ThingWorx?
Hello
If you have documentation on the protocols supported by ThingWorx, please provide a link
If possible, I would also like to have a example document of the relevant protocol.
The most necessary example document is how to communicate data with TCP.
Thank you.
PS. Also let me know how to change the Thing's configuration value that using the extension's template through the service.
Is it self-service? Or should I try it through the REST API?
posipovaAnswer
20-Turquoise
September 28, 2017
Hi Seonho, could you please share some more detail to your requirement and may be also some description on the use case. It'd be easier for us to better understand and respond to your request. How you intend to connect to ThingWorx? Is it via the WS EMS or one of the EDGE SDKs? Since they use AlwaysOn protocol.
CHASEONHO18-OpalAuthor
18-Opal
September 28, 2017
Hi Sushant Pandey
There is no distinction between approaches.
However, I would like to have a document describing the formats that support the protocol.
In the case of MQTT Extension, WS EMS and EDGE SDK are not.
I would like to have a document that describes how it works and what is required for other protocols.
Sorry for the lack of explanation.
I want documentation on the protocols supported by ThingWorx.
Theni think  i can figure out how the supporting protocol connects to ThingWorx through that protocol document.
I do not have a deep understanding of the protocol and I think I need to approach it this way.
The other way is because I'm not proficient in English
So, I would appreciate if you could let me know what keywords you would like us to find relevant information on the PTC support page or community.
Thank you.
posipova20-TurquoiseAnswer
20-Turquoise
September 28, 2017
