Create a custom file repository in thingworx
Whenever we create FileRepository thing, it is always creating in /ThingworxStorage/repository. I want to customize this folder location, Please help.
Hello Thangavel Ayyasamy​,
Since version 7.0 Thingworx allows to customize location of your Thingworx Repositories. All you need to do, is to create a folder named ThingworxPlatform in the root of your Tomcat/Thingworx installation (e.g. if your Tomcat is installed in C:\Program Files\..., you should create a folder: C:\ThingworxPlatform and so on).
There you should create a file named platform-settings.json. Inside you can put a various configurations for your Thingworx Platform, also for the File Repository root location. The configuration should be in JSON format. The minimal necessary configuration for your task would be:
    "PlatformSettingsConfig": {
          "BasicSettings": {
              "FileRepositoryRoot": "<new_repository_root"
For another possible configurations and the general information, please refer to the Help Center: Digital Media Publisher and Thingworx Installation guilde.
Please note, that all necessary read/write permissions needs to be granted to the location specified. Otherwise your Thingworx won't startup properly.
Hope it helps, don't hesitate to ask for further assistance.
J.
Hi J.,
I did that and it creates a folder repository in the path but Thingworx do not recognize it when running services. Are there any other step after that? It is still looking to ThingworxStorage folder.
Thanks!
Felipe Duarte
Just to try, if you want to set it out of ThingWorx Storage, you may try with ../../../....... whatever
i tried providing storage & backupStorage folder location in platform-settings.json file as below
"BasicSettings": {
"BackupStorage": "D:/teststorage/ThingworxBackupStorage",
"Storage": "D:/teststorage/ThingworxStorage"
doing this creates a ThingworxStorage & ThingworxBackupStorage both folders in mentioned location
now moving to composer i created filerepository testthing. exported this file using repository as SystemRepository, files gets exported to D:\teststorage\ThingworxStorage\repository\SystemRepository
that means ThingWorx is reading the mentioned location.
