Create a timeline
I would like to following the status of my equipment (running, down, ...) as a timeline chart like the picture below.
I have tried the Gantt chart that is not so bas but it generates several lines for each event. I want only one line.
Did someone of you already build such a graph ?
22-Sapphire I
I believe the manufacturing starter apps come with a widget that would work, ootb you could use the label chart and make it a stacked chart
