Create a variable browser tab display name
Hi everyone,
I am currently working on TWX 9.3.4-b1190 and I wonder, if there is a way to change the Browser tab display name dynamically. Right now, you can not bind the Title property on a master mashup and the solution provided in the link below does not seem to work for newer TWW versions.
Solved: how to make make a variable title for a Master Ma... - PTC Community
Best regards
Markus
nmutterAnswer
The error with previous functionality is now 'Uncaught ReferenceError: $ is not defined'.
I think you can only do it with a custom extension widget now, which executes
document.title = newTitle;
https://developer.mozilla.org/en-US/docs/Web/API/Document/title
With the replacement of "Non-Secure"-Expressions (MigratingNonSecureFunctions.html) the manipulation of the DOM (like changing title) is no longer possible. At least I did not find a way for now... The expressions are executed in some "sandbox"-environment having only a limited scope. So $ (from jquery) is not available anymore.
nmutter17-PeridotAnswer
