Create InfoTable using Java Extension SDK
I am having troubles creating Infotable objects using the Thingworx Extension SDK. I have tried multiple methods and no seem to work.
Using From JSON
I tried to use the fromJSON method but i didnt work.
JSONObject jsonObj = new JSONObject("{\"dataShape\":{\"fieldDefinitions\":{\"id\":{\"name\":\"id\",\"description\":\"id\",\"baseType\":\"STRING\",\"ordinal\":0,\"alias\":\"_0\",\"aspects\":{}}}},\"rows\":[{\"_0\":\"178498585\",\"_1\":1531849323285,\"_2\":true},{\"_0\":\"178496396\",\"_1\":1531849187726,\"_2\":false},{\"_0\":\"178482871\",\"_1\":1531848400119,\"_2\":true}]}");
InfoTable it = InfoTable.fromJSON(jsonObj);
Building From Scratch
I have tried to build the InfoTable from scratch but no methods work.
1) Create Field Definition and using addField
InfoTable myIF = new InfoTable();
FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER);
myIF.addField(Field1);
2) Create DataShapeDefinition -> Add field to that definition -> use infotable constructor with the data shape definition as input. I have also tried to use BaseTypes.String.
DataShapeDefinition dsd = new DataShapeDefinition();
dsd.addFieldDefinition(new FieldDefinition("MockedField", "STRING"));
//also tried
dsd.addFieldDefinition(new FieldDefinition("MockedField", BaseTypes.STRING));
InfoTable it = new InfoTable(dsd);
What is the correct way to create the InfoTable Object?
Thanks!
Hi @bwinslow24 you'll need to invoke the InfoTableFunctions class to create an Infotable, I've created a sample ThingTemplate below which contains a Property called "InfotableAsProperty" and a service called "CreateInfoTable" which also creates an infotable, and finally a datashape which is used in both Infotables
@ThingworxBaseTemplateDefinition(name = "GenericThing")
@ThingworxPropertyDefinitions(properties = {
		@ThingworxPropertyDefinition(name = "InfotableAsProperty", description = "", category = "", baseType = "INFOTABLE", isLocalOnly = false, aspects = {
				"isPersistent:true", "dataChangeType:VALUE", "isEntityDataShape:true", "dataShape:CustomDataShape" }) })
public class CustomInfoTableExtension extends Thing {
	private static Logger _logger = LogUtilities.getInstance().getApplicationLogger(CustomInfoTableExtension.class);
	private static final long serialVersionUID = 1L;
	public CustomInfoTableExtension() {
		// TODO Auto-generated constructor stub
	 * CreateInfoTable service creates an infotable.
	@ThingworxServiceDefinition(name = "CreateInfoTable", description = "Creates an infotable", category = "", isAllowOverride = false, aspects = {
			"isAsync:false" })
	@ThingworxServiceResult(name = "Result", description = "", baseType = "NOTHING", aspects = {})
	public void CreateInfoTable() throws Exception {
		_logger.trace("Entering Service: CreateInfoTable");
		FieldDefinition Field2 = new FieldDefinition("Field2", BaseTypes.STRING);
		myIF.addField(Field2);
		TagCollection mytag = null;
		EntityServices es = new EntityServices();
		try {
			es.CreateDataShape("CustomDataShape", "Created from the extension sdk", mytag, myIF);
		} catch (Exception e) {
			_logger.error("Failed to create datashape" + es.getName());
			e.printStackTrace();
		InfoTableFunctions myImf = new InfoTableFunctions();
		try {
			myImf.CreateInfoTableFromDataShape("Infotable1", "CustomDataShape"); // creates infotable from a datashape.
			_logger.error("Failed to create Infotable" + myImf.getName());
		_logger.trace("Exiting Service: CreateInfoTable");
Hi @supandey,
Thanks for the response, but its not exactly what I'm looking for. I should have explained a little better in my question. I am trying to mock the output of QueryBooleanPropertyHistory so I can test parts of my code with JUNIT. The output is an InfoTable. I want to build an InfoTable object and use that in my tests. I can instantiate the InfoTable object but when I try to add any fields or rows it doesn't work.
Brandon
